Removing Airbox?
2 reading
25K views 14 replies 7 participants last post by  Bradders-92
#1 ·
Hi guys,
New to the forum, so this is my first post.
Can someone tell me how to remove the airbox, or point me to some sort of photo description guide on how to do this.
Also what tools are required.
Cheers.
#3 ·
What he said, i may do a tutorial on this since i removed it a few days ago tryin to change the bulbs which never succeeded xD
#7 ·
Here it is mate
Tools u need (T20 torx is the one u need to remove the airbox bolts)
U need to undo the ring to losen grip on the pipe and undo the clip on the airfilter sensor
The Airfilter sensor jus unclips wen u apply some pressure to the back of it u'll feel a lil peg bit if u like and jus press down and pull.
Next undo the ring the top ring by undoing the bolt on it slightly so that it can move freely. Pull the pipe straight out afterwards.
The 4 bolts ur looking for are as follows below hightlighter in the red circle.
After that just lift the top cover straight off starting from the right side and liftin up towards you.
From there on its just a matter of undoing the lil tube at the bottom top right hand corner of the box. Then just pull the bottom of the airbox out.
Hope this helps mate and sorry it took so long, had a hectic day.
Jay
